Gearing for cam motor and nitrous
think that I will run out of gears and could run 28" if I needed to. I just can't decide between 3.73, 3.90 or 4.10's. At the most I will have 650hp on nitrous in the future when I rebuild the motor. Some people say lower gear and others say higher gear.....I just need a little help.
Hp and weight will dictate trap speed. From there, selecting gear ratio is really a math exercise based on tire size. Tough part is to be realistic on hp and get your trap speed right.
S60 sounds like a great choice. Who's drive shaft are you planning to use?
JMHO Trending Topics
