what is your favorite way to pull timing?
I have a timing tuner but I am tempted to just reflash with hp tuners when I want to spray.
What about the msd timing twister can you see that the timing is pulled when data logging?
What way do you guys pull timing for juice?
you dont control the fuel with iat tables, it is used to pull timing, my belief is you get your motor dialed in the pull x amount of timing for nitrous and tune with nitrous via pills or fuel pressure if you have a standalone
sorry for the threat hijack op, but could someone give a definitive answer on which resistor to use with this mod? I see conflicting ones across this board. thanks
