Spray on high mile
1) Do a leak down test on your cyl. to make sure there are no issues witht he compression of your motor. (Just to be safe) if its not your daily driver spry it lol.
2) Read the stickies on how to spray just to make sure you do it right.
3) Replace the stock fuel pump if you havent all readys
4) Get the right tune in the car and the right plugs
5). You can get away with a 100 to a 150 shot. on a stock block with no issue if the tune is right and the right plugs
If you have questions pm me. Or call Chris @ Nitrous Outlet to help you set it up.
Let me know if you have any more specific questions or want to look over your whole setup.
The presence of oil into the combustion chambers is a big cause for detonation. Detonation + nitrous = bad
Engine longevity using nitrous will depend on how good was the maintenance and care since new.
100K miles of a well cared engine aren't the same as 100K of a neglected engine.
Use caution, check plugs and use good fuel. Stop if weird noises or strange things happen.
