nitrous fuel?
Old May 31, 2011 | 05:00 AM
dr ls7's Avatar
Default nitrous fuel?
ok guys looking for some friendly advice on fuel to run with nitrous 50hp-175hp
engine late model LS7 427ci 11.7 comp approx 700hp N/A will run on a diet of E85 fed by SV1 carb and magnafuel pro500 pump and a 24 gallon tank
nitrous will prob run from same tank of E85 fed by Holley Blue pump,
my question is will this be ok of should i play it safer and run a seperate tank with another type of fuel ? C16?
Thanks in advance jake
Old May 31, 2011 | 01:43 PM
Phantom's Avatar
e85 works great with nitrous. I don't think the holley blue will supply enough volume to fuel both your carb and your nitrous. I would run a separate tank and pump up front for your nitrous with e85 in it.
Old May 31, 2011 | 05:32 PM
nandos_z28's Avatar
Looks like he is running the Holley blue as a dedicated Nitrous fuel supply and a Magnafuel for the motor...
Old May 31, 2011 | 05:34 PM
Phantom's Avatar
oh my bad! i missed that part. i would suggest a holley black either way. good luck!
Old Jun 2, 2011 | 12:58 AM
KFZ)^'s Avatar
Start with the 75 shot on E85 and work your way up from there, reading plugs etc as you go. The C16 is definitely a safety factor but of course it adds a little complexity to the setup and costs much more per gallon. But since you aren't planning on spraying bigger than a 175 shot, E85 will probably be fine, assuming the tune-up is good to go. But what the hell do I know? Go with your gut, it's your car and your money!
Old Jun 2, 2011 | 05:27 AM
MontecarloDrag's Avatar
It will work fine.
However you'll need a bigger fuel jet for the same HP, because jet sizes for each power level are for gasoline.
Old Jun 2, 2011 | 08:53 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Hey Jake,
That setup will work just fine. The only change need to be made is to just the plate according to low pressure e85.
e85 has a different look on the plug. Me and Dave can go over this with you once we get the plate plugged.
Old Jun 2, 2011 | 03:07 PM
ShiznityZ28's Avatar
I thouhgt E85 was in the 98-105 range as compaired to gas depending on blend and test. On 700hp + 175 id want at least 110 . I gues it will be fine but if you have a 2nd tank why not run some e100(in the 108-115 range) or something to help that?
