What plate is this?
NOS will have the jetting for it. As far as what its capable of, I would spray a 100hp with it and check distribution. I would not take it over 150hp IMO.
I would NEVER spray that plate at those power levels. Also only NOS style jets will fit. Ours, NX, TNT, Harris and many others jets will not work.
I have a 90 mm HSW plate, but I don't have a 90 mm intake. http://images.ibsrv.net/ibsrv/res/sr...ch/gr_bomb.gif
First I would pull those fittings out and inspect it. Just looking for obvious signs of abuse or machining that was not done by Holley. Reinstall them with some red loctite. Then blast it.
That is up too you. If your wanting the best plate out there, I think it is our design. Your looking at 260$ for a plate conversion, so that may or may not be worth it to you since you own this plate. But it does come with not only a well designed plate but also our tech support (Which your enjoying now
) If your wanting to spray 100hp or less you will be fine as long as you check distribution. If you want 150hp or above, or just a better (IMO) plate then we can talk about ours. If not, jet that plate up and make a clean plug pass and we will see if we cant get you lined out with what you have.
I'm considering buying a nicer plate or maybe some one will trade me for my 90 mm plate.
Nitrous Outlet has always been more than willing to answer any of my questions with no run around BS whether it be through email or on the phone. I never did much testing with the HSW plate before I got rid of it so I can't say one is better than the other, BUT I know how even my plugs look and how well my truck runs with the plate from Nitrous Outlet. It's the only plate I'll recommend for someone spraying through the front of the intake
