1/8 mile et motor and nitrous times
Ok I just thought about this When I bought my 12 bolt it had 4:30 gears in it and I took them out for 3:73 but I was also running a 4l60e now with the different ratio of the th350 maybe I should just stick the 4:30s back in it and see how it does. Because there isn't a whole lot of difference between a 4:30 and a 4:10 and it would save me 250 bucks on a new ring and pinion??? Thoughts..... Anybody? Lol
I try to shift around 6300 or 6400. Lane set my limiter at 6800 and on motor with the 3:73s when I went 7.30s I turned it a lil tight in second going through the trapps at 95mph and around 65-6600
Update at moulton drag way. I went 7.21 1.60 60ft @97 mph on the motor and 6.54 1.47 60ft @ 107 mph on spray. Nothing ha changed but I change pinion angle from -2 to -4. Went with a 10 inch rim instead of a 7, and put a msd 2 step on it. What do u guys think. I'm going to go with the 4.30 gears that I have already instead of the 3.73. The worst that could happen is it will slow it down but maybe I cam get it into the 30s on spray with them
60ft on bottle looks better. I'm surprised you can't go 1.5's on motor. What tires are you running?Our 1/8th mile times are very close to each other. Your car is moving out though.
Sounds like your converter is too tight. I run a PTC as well, but it works just fine, car only turns 500RPM more on nitrous than motor...you could always have them redo it.
I'd start with the gear and see what happens..3.73 to a 4.30 will help. I don't think 3.73-4.10 would do much of anything. You gota think about going from a stock height 26 to 28inch tire is killing your gear
well I've gotten a best of 1.31 on a 125 shot but always ran 1.35-1.38 but have always had low mph ranging from 98-100mph going as fast as 6.68. thought maybe the converter was only working so well down low because the car weighs 3600lbs raceweight and once the car got out it would slow down due to the verter being so tight. This is a th400 car 4.11 gear 325/50/15 radial.
BTW I pulled my motor this week debating on doing a 383 myself with the tsp 5.3 heads I have already and having a cam specced to work well with the vic jr/4150 as I've always run an ls6 intake.
#34
You need to change that 2800 stall to a 3600. I wouldn't go higher than 3600 since your on spray. Your motor 60' are low because you have not shot out of the hole with a 2800 converter and your current gears. A properly spec'd 3600 converter and spraying out the hole will immensely improve your 60' time.
I wouldn't worry about heads or a dedicated fuel cell until you get a new converter, then see if you need more help getting out the hole with lower gears. I think a new converter will solve all your problems and then help you gain some on top of that. Then go with a dedicated fuel cell and then heads.
#35
#36
BTW I went with PTC's recommendation and sprayed from a 7.8 on motor@87mph to 6.70's on a 100 shot but it never responded to more n20. Again my fault I don't think the ptc converter was an issue but it was PIG **** tight on motor. 1.7 60ft down to 1.3's and 1.4's. flashed around 3000 on motor and 4200-4400 on a little jug. PTC said I need to hit it with more bottle to get it out of the hole harder.
#38
Ok I put the 4:30s back in and here are the results
4:30s
Motor - 1.65 60ft 7.17et @ 97mph
Spray - 1.57 60ft 6.60et @ 107mph
3:73s
Motor - 1.60 60ft 7.21et @ 96ish mph
Spray - 1.47 60ft 6.54et @ 106 mph
Ok to all you gooroos this doesn't make any sence to me, can any of you give your advice on this. I think I'm going to go back with the 3:73s for hooking purposes and consistency and I know I need a bigger stall converter but I'm not going to do that unroll I get my 250 shot ready . Btw I understand why the 60ft was slow and that was because the car was spinning bout 10 ft out but why would the mph be higher with the lower gears and if it picked up on motor why didn't it pick up on spray?
4:30s
3:73s
#40
New stock shocks front and rear, soft rear springs (not sure the brand). Spohn body mounted ta (-4 degree pinion angle) spohn adj lca with relocation brackets in bottom hole, subframe connectors and pa racing k member
