Another nitrous and plug??
Old Jun 29, 2011 | 07:55 AM
2camaros6702's Avatar
Default Another nitrous and plug??
I have been running NGK TR6's for about 5 years and spraying a 125 shot with no problems and just recently I sprayed a 150 shot. I am changing them to either the BR7EF's or B8EFS, I have not made my mind up yet. I am wanting to stay with the 150 and sometimes maybe a 175 shot so my question is will my car make more power by just going to a colder plug on the spray and with all mods in my sig what plug do you suggest. Keep in mind I do drive my car every day.
Old Jun 29, 2011 | 08:30 AM
SargeZ06's Avatar
I run my BR7EF's up to a 175 shot. When I go 200 I'll change to an 8 range.
Old Jun 29, 2011 | 08:58 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Br7ef is what need to be in there. No question on that one. It fits the combo to a T.
Old Jun 29, 2011 | 11:20 AM
Thanks for the feed back guys. Should the car run better on the 150 shot by just changing the plugs?
Old Jun 29, 2011 | 11:40 AM
Guest
Posts: n/a
They will keep it running.
They will open the tuning window up and keep everything safe. It will not really pick up ET.
Old Jun 30, 2011 | 10:42 AM
Frozen WS6's Avatar
When I first got my car I sprayed a 100 shot a few times on tr6, and went 10.02-10.04 all day. I did get slight detonation so I put in the 7's (the correct plug) and my only change and went 9.89. With 6 degrees of timing pulled (my 150 tune).
The One and Only time I sprayed the 150 on the 6 it went 9.88. With my only change being spark plugs. Put the 7 in it went 9.75 and would have went faster my next pass if I hadn't blown my hood off ending my day.
So I would not be surprised to see you pick up some more and run faster.
