Completely New to Nitrous
My question is, what are my main concerns (things breaking or giving out), which system would probably be the best bet for my set up, I will not go above a 150 and if i go with the bottle, what are some things that will NEED to get upgraded.
Sorry for being such a noob at this, don't bash me too hard! I'm just trying to get the most info before I take the plunge. also, is tuning required after install. Or if I stay around a 100 shot, should i be safe to run it without a tune.
Tuning is definitely required. It's mainly pulling the plugs out to check the timing but you don't want to go cheap and not pull any timing back or check anything out. Look around the forums, maybe give Nitrous Outlet a call and you'll be good to go.
Answering these questions will let us help you
The wet kit is what I'm leaning to so far, and probably a 100 shot, or 125 shot. I'll give nitrous outlet a call on Tuesday after the holidays to get an idea on pricing and what kit they suggest. I just wanted to see what the Ls1tech community would have to say.
I appreciate the answers so far, I'm just trying to get an idea of what's out there.
Thanks again for dealing with my questions. I plan to research more in the next few days, but wanted to know what you all think
Spend the rest on heater, window/wot switches, timing tuner
You will have a good system that activates safely via the switches, you can pull timing when you want to destroy the feeling of the school mates
as long as you pump the bottle pressure to 950 - 1000 psi where it should be through the bottle heaterThe right spark plugs for the size of shot you are looking for is NGK BR7EF gapped to .035
You can also throw gauges as future mods .. AFR, N2O Pressure, Fuel Pressure
I have one question .. What is the brand of the fuel pump you just swapped ???
The answers are awesome so far, thanks guys
These guys lined it out pretty well for you. The big thing about keeping it safe is the things other than the system.
Things like the Fuel pressure safety switch and nitrous filter. A window switch is golden as well.
If you need a hand or some prices give me a shout.
