4.070 6.0 block
4.070 6.0 block
I'm building a 6.0 for my regular cab or my vette, havnt decided what to put the motor in yet.
Anyway I've run across a set of 4.070 pistons and I'm tempted to pick them up but I've got a question before hand.
My question is would a 377 work with nitrous? I'll be using 317 heads and would like to mill them but with th pistons being +3cc dome I dot know how that will work.
Thanks in advance
Steven
Thanks in advance
Steven
Good for 300-400. It's just a guess but if your 317's are stock chamber and you have a +3cc dome you are still under 10.5:1. Mill them .030 if you have enough PTV. Should be close to 11:1. If you have the right ring gap no reason a 300 shot won't work with the right tune up.
I greatly appreciate the info and help.
Thanks again
