Meth an nitrious? Or not?
Old Jul 7, 2011 | 01:39 AM
fatboy_98transam's Avatar
Default Meth an nitrious? Or not?
ok here is the ? can i run methanol injection on top end like off a controller an run nitrious for bottom end power? if so please add details ive just installed vortech 8 psi and new to the forced induction game... always justbuild big motors an powerglides to run 1/8 mile bracket racing so any info will b helpful.. thxs ahead of time
Old Jul 7, 2011 | 06:18 AM
mrdragster1970's Avatar
6 & 8 Second Club
I would KISS, pick one, and see what you can get out of it.
I'm definitely not an expert, but N2O worked excellent on a couple of my friends that tried it on a boosted combo.
Even tiny 50-100 hits gave some amazing gains on blower cars.
Old Jul 7, 2011 | 07:56 AM
DietCoke's Avatar
Meth is kind of pointless as a twin with nitrous. Nitrous cools the intake charge enough on its own.
Old Jul 8, 2011 | 01:51 AM
so no need for both i guess
Old Jul 8, 2011 | 08:45 AM
Graham@NitrousOutlet
Guest
Posts: n/a
Depends on what Mix your running and what the goals are. 70/30 is going to have less benefits as the cooling will be less pronounced once the nitrous is spraying. But it still going to raise the effective octane of the mix slightly and also will make the combination less sensitive to detonation.
100% meth will certianly help, mostly because of the octane added to the mix.
Both require tuning and do add some variables to the tuning but nothing too difficult. If you have, tell the tuner your working with and see how he would like to go about it.
Old Jul 8, 2011 | 01:39 PM
for the most part i was want to run both mostly for cooling purpose but the nitrous for bottom end mainly. another ? should either go b4 the supercharger or both or neither? both after the charger?
Old Jul 8, 2011 | 02:25 PM
Guest
Posts: n/a
Why don't you give me a shout here at the shop? 254-848-4300
Lots of variables on how you want it set up exactly. A lot of it is based on how your tuning and who is doing it. I would like to go over everything in the combo if you have time.
