Nos 2 stage or fjo controller
Old Aug 5, 2011 | 09:21 PM
Martin718's Avatar
Default Nos 2 stage or fjo controller
Not wanting to use either for progressive controllers just looking to use for 2 stage activation off a timer. I am pretty sure both can run off a timer and activate two stages so.... If I'm correct is there really a difference between the two controllers??
Old Aug 6, 2011 | 04:14 AM
WheelsUp84z's Avatar
FJO needs a windows based laptop to program, thats about the only difference.
Old Aug 7, 2011 | 09:36 AM
LS1LT1CAM's Avatar
fjo is much better I have had both took the nos off and used fjo
also have seen a couple of cars with two edelbrock controller in it (Tim Hendrick's green firebird) he has been 5.05 in the 1/8 on 275s with a small block and two stage plate
Old Aug 7, 2011 | 06:21 PM
Graham@NitrousOutlet
Guest
Posts: n/a
Who does the tuning in your car? Do you datalog often? Do you own a laptop?
Old Aug 7, 2011 | 09:29 PM
Martin718's Avatar
We are doing our own tuning, and yes we have a laptop and data log.
Really could use nitrous outlets help with a diagram for my wiring in my other thread in here
Old Aug 8, 2011 | 09:06 AM
Guest
Posts: n/a
FJO is the better option then.
Which thread?
Old Aug 8, 2011 | 05:54 PM
99articfrc's Avatar
if you want to change the settings on the fly depending on your race the nos is the way to go so you dont need to have ur laptop to change the file in the car
