fuel pressure regulator ?
Old Aug 5, 2011 | 09:21 PM
6th gear's Avatar
Default fuel pressure regulator ?
I am trying to peice together a stand alone fuel system for a direct port kit. I do not have 800 bucks to buy one already made. So im throwing one together. My ? is when looking for a fuel pressure regulator what PSI should i look for? 4.5-9/5-10/5-12 ect ect. And what should it be set at for a 200 shot? Thanks for your help?
Old Aug 5, 2011 | 10:45 PM
SSPerformance's Avatar
Flowing psi is going to depend on your jetting.... You can go with a holly blue pump and reg for like 130ish
Old Aug 6, 2011 | 07:01 AM
6th gear's Avatar
Thank you sir! This is a learning processes for me, as i have never messed with direct port or a stand alone.
Old Aug 6, 2011 | 07:25 AM
6th gear's Avatar
Here is a ruff sketch what i am assuming how a stand alone is plumbed. The fuel cell i am useing is a 3 gal aluminum. It has a -8 an outlet,-8 an return,and a -8 an vent. I am assuming i do not use the return line correct? Also on the other side of the fuel regulator is where i switch over to a -6 an fitting to hook into nitrous solenoid.
Old Aug 6, 2011 | 11:44 AM
Doug G's Avatar
No return is called a dead headed system...and will be fine.
As for your fuel pressure regulator, 4.5-9 will be fine (lower pressure uses bigger jet)
One thing I would add is a low fuel pressure cut-off switch (incase the cell goes empty or the pump sucks air)...basic safety
Old Aug 6, 2011 | 12:03 PM
6th gear's Avatar
Awsome advise. But what should my MAX and MIN psi be on the cut-off switch?
Old Aug 6, 2011 | 02:06 PM
Doug G's Avatar
I "think" they're pre-set to 5psi ? There may be an adjustable one out there ???
Drop Graham a PM...I'm sure he has what you'll need.
Old Aug 9, 2011 | 09:27 AM
Graham@NitrousOutlet
Guest
Posts: n/a
You only need a MIN. It really just depends on the pressure you want to run. I would start at around 10 psi and have the FPSS set at around 7-8psi
They all come adjustable. The way the come as far as PSI setting can vary a little. I would at least verify the setting before ever installing one.
Thanks btw for the referral!
Old Aug 9, 2011 | 04:14 PM
Doug G's Avatar
No problem Graham...I'm still learning on this stuff myself and don't want to give someone bad advice and toast their motor....bad enuff if I do my own.
Old Aug 10, 2011 | 09:23 AM
Guest
Posts: n/a
That was really funny.
