Which window switch is best?
Old Aug 10, 2011 | 07:04 PM
speedfreak2685's Avatar
Default Which window switch is best?
I am buying a used nitrous kit from a buddy of mine and he has both a MSD digital widow switch and a MSD window switch that uses the pills to adjust when nitrous comes on and off. I have heard some bad things about the digital one messing up and the one with the pills being my best bet but I have never used either. The digital seems alot more convenient. I can have either one. Has anyone had experience with either of these both good or bad. I need to make a decision in the next few days.
Old Aug 11, 2011 | 09:25 AM
Anyone?
Old Aug 11, 2011 | 09:35 AM
01SOMZ28's Avatar
I've been using the MSD digital window switch for the last 4 years and it has never gave me any problems. Digital > pills
Old Aug 11, 2011 | 10:41 AM
Sweet. Thanks for the input
Old Aug 11, 2011 | 01:00 PM
1lejohn's Avatar
MSD digi here also. I also had good luck with the Timing Tuner, it had a switch built in.
Old Aug 11, 2011 | 03:25 PM
Sweet. Looks like im going with the digital.
Old Aug 11, 2011 | 07:32 PM
mike c.'s Avatar
I HAVE A MSD WINDOW FOR $40.OO. iT'S NOT A DIG,BUT WORKED FOR ME WITH NO ISSUES.
Old Aug 11, 2011 | 08:05 PM
I already have both window switches just trying to decide whice one to use
Old Aug 12, 2011 | 05:54 PM
RsSean's Avatar
I have a digital one, absolutly love it. No problems out of it and I have had for atleast 2 yrs and has been in the car with the previous owner for 3 no issues. Digital>pills
Old Oct 30, 2013 | 09:24 PM
Heavy H.P.'s Avatar
Bump
Is there any reason to go Digital over the one with the pills?
Any pros or cons?
Have a Pilled switch and looking at a digital.
Old Oct 30, 2013 | 09:34 PM
Carter01's Avatar
I have the digital one and it has worked flawless for 3 years. Very easy to wire and extremely easy to set rpm points.
Old Oct 30, 2013 | 09:45 PM
PaSteLaSo4U's Avatar
Digital here as well, it works like it should
Old Oct 31, 2013 | 05:06 PM
brandon@nitrousoutlet's Avatar
I'd run the digital out of the two. Much easier to setup and is programmable.
Old Nov 2, 2013 | 08:06 AM
Heavy H.P.'s Avatar
Hope this does not sound stupid but explain alittle more please?
Old Nov 2, 2013 | 03:11 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
^Clown, save your money and keep the pilled switch!
Old Nov 5, 2013 | 08:04 AM
slvr T/A's Avatar
Running the MSD Digital also. Hasn't given me any problems and works perfect. Super easy to set up.
Old Nov 5, 2013 | 09:58 AM
With the digital one you can program in the coil setting vs. cutting the loop wire in half to go to 4 cyl mode.
