gas and plugs
Old Aug 13, 2011 | 08:20 PM
fatboyzcamaro's Avatar
Default gas and plugs
hey guys i was wondering whas the best gas to run n my cam only 200hp nitrous powered ls1.whatever is best the nitrous ill use all the time even on motor instead of switching back na fourth.i only have a 4 gal cell.
i also was wondering about spark plugs.i been reading alot of different setups.again whatever plug is good for the nitrous ill leave n on motor also.unless its that much of difference in power lol.thanks in advance.
Old Aug 14, 2011 | 07:03 AM
Doug G's Avatar
I don't know much about E85 so I would have to point you toward my buddy Eric...
http://www.horsepowerinnovations.com/
He races, mods carbs for, and sprays on E85.... I think he would be the one to talk to.IMO.
Old Aug 14, 2011 | 07:46 AM
Carter01's Avatar
When i was on the 200 shot I liked VP Blue 112 and ran a br8efs NGK gapped at .032. PM me if you have more question, many things can change the tune-up.
Old Aug 14, 2011 | 01:36 PM
thanks cater
Old Aug 14, 2011 | 03:30 PM
dnkynrbk's Avatar
I run vp 110 #9 plugs gapped @32 stay away from e85
Old Aug 14, 2011 | 05:11 PM
Doug G's Avatar
E85 is ??? like 110, but being alcohol you need to jet it up. It does work
My buddy Eric's Camaro.... http://www.youtube.com/watch?v=10Y49WEinMI
Old Aug 15, 2011 | 04:40 PM
Lt1Porsche's Avatar
I was under the impression E85 burned slower so less was need? I may be wrong...
Old Aug 15, 2011 | 04:45 PM
Graham@NitrousOutlet
Guest
Posts: n/a
Depends on how the car is driven. Assuming you said you would race gas in the main tank,
I would assume this is track only.
I would run whatever has the most octane in your area (c16 for example) and then run a b8efs plug.
