NOS mini controller wiring ?
Old Aug 14, 2011 | 07:57 PM
IH8FORD's Avatar
Default NOS mini controller wiring ?
I have the NOS 15974 mini controller. The controller has two heavy gauge wires to use for both stages to the solenoids. The diagram shows to wire them straight to the solenoids without any relays between the controller and the noids. The only power source to the controller is a small gauge white wire for the coming from the main switch.
Can I put relays between the controller and the solenoids? I don't see How that one small wire can support the current for the solenoids. This is the wiring diagram.
http://www.jegs.com/InstallationInst.../741-15974.pdf
Old Aug 14, 2011 | 08:29 PM
krissoto's Avatar
If im not mistaken, the relay's are built in the box the wires itself are coming off of.
Old Aug 15, 2011 | 07:28 AM
98sscammed's Avatar
The blue and red send the ground signal.
Old Aug 15, 2011 | 07:53 AM
IH8FORD's Avatar
Thanks, I was looking at the diagram wrong. I thought that it should be like rpm switches that hook up to the ground side. I can just hook up the 12V side with relays, Correct?
Old Aug 23, 2011 | 02:07 PM
Kyle@NOS's Avatar
LS1TECH Sponsor
Yes the solenoids can be powered through relays. See attached schematic.
Kyle
Old Aug 23, 2011 | 06:36 PM
IH8FORD's Avatar
Kyle
Thanks, that will work I like that diagram better.
Old Feb 21, 2012 | 10:29 AM
Racer383's Avatar
I am trying to hookup a 15974 NOS progressive controller to an MSD 8625 Timing Twister for my stage 1 retard. Love the diagram in the post above
It is my understanding the yellow ch1 output control wire outputs a ground signal. Would this be the trigger I would use for the MSD retard? Since it is a ground output I assume I would use a relay to "convert" to a +12V signal?
Thanks
Mark
Old Feb 27, 2012 | 01:46 PM
Racer383's Avatar
bumping....
Old Feb 28, 2012 | 11:54 PM
Nitro Dave's Nitrous Outlet's Avatar
Kyle
Kyle FTW
Old Apr 17, 2013 | 08:18 AM
Jeremiahsc5's Avatar
Thanks
Mark
I have the same question. Sorry this is an old post guys.
Old Apr 17, 2013 | 12:01 PM
brandon@nitrousoutlet's Avatar
Yes a relay would be how to convert from a ground to a +12V signal.
Old Apr 28, 2013 | 10:12 PM
Thank you. Does anyone know if there is a diagram for this set up floating out there on the net.
