question about wiring the purge solinoid
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hey guys, I came up with this diagram and wanted to run it by you guys first before I set it up. Will this diagram be ok? If not, what will be better? Also, what is the best wire to tap into for the power supply? Thanks!
![](http://i102.photobucket.com/albums/m113/jasonbaucom/purgediagram.jpg)
6 & 8 Second Club
I would prefer the purge run off the N2O system main on switch.
It would suck to lose a bottle or get a face full because someone leans on or shorts the push button.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
6 & 8 Second Club
I run the little baby solenoid, so I just use a push button, with the power coming from my switch panel.
Any other solenoid, I would definitely use a relay, but I did an amp draw and it was tiny, well under the switch ratings
Guest
Posts: n/a
The purge I have is one of yours. Its the big show one. After doing a little digging I think it does need a relay. Is this correct? Any info on the relay and wiring will be awesome. Thanks! Sorry Im a noob when it comes to nitrous.
yeah, good point. I think Ill keep this in mind.
http://www.nitrousoutlet.com/manuals.asp
The wiring diagram and instructions are here. Right hand side. If that does not get you taken care of let me know.
6 & 8 Second Club
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
I'm not in a real car, (Pro-Mod, Top Sportsman) and the purge is on the column, so when I get in or out,
take the wheel off, I hang it from the column, and it can hit the button.
Plus I think of & worry about every little thing most of the time.
I just like the piece of mind, and safety to know if someone is crawling around, nobody will get a face full of N2O.
![](http://img231.imageshack.us/img231/1476/hpim0578cr8.jpg)
