A few beginner nitrous questions
I would not spray the car without at least a racetronix setup. No way would I trust a stock pump at that power level. Remember that thing is over 11 years old now.
You need to be on a tr6 on motor probably. For any nitrous you need to be on a br7ef NGK#3346.
Timing will depend on the size shot. Before we get to that, what all does the system consist off that you have so far? Want to make sure you have all the needed components.
If your on stock pistons and flycut you might have issues tho, myself and a friend both cracked the ringland right where the valve pocket was cut with safe nitrous setups.
