Ready to say F#$k it......
Old Aug 24, 2011 | 08:42 AM
lncboytre_d's Avatar
Angry Ready to say F#$k it......
This is mallory 685 box number 3, the car will not start with it connected. When I use the by pass harness the car fires right up....WTF!!! I retraced the wires with a test light 3 times, I even called the tech line. The tech at mallory said the box is not compatible with the lt1. Bullshit. I'm wondering if I should just go msd. Which msd box do I need? I need a window switch and timing retard. This is really pissing me off.
Old Aug 24, 2011 | 10:15 AM
87silverbullet's Avatar
Here you go
http://www.jegs.com/i/MSD-Ignition/1...oductId=762123
You won't need the opti or coil since you most likely have them already. Just the box and adapter harness
Old Aug 24, 2011 | 11:28 AM
Originally Posted by 87silverbullet
Here you go
Thanks for the link. I was pretty frustrated earlier this morning when I made this post. I was literally sitting in the drivers seat livid. I'm good now, it's 11:30 and I'm ready to get back in the fight. Thanks again.
Old Aug 24, 2011 | 11:43 AM
Graham@NitrousOutlet
Guest
Posts: n/a
This is nuts Trey!
Try and get with Larry@AMS, I bet he can help get you lined out. Ill shoot him a pm for you as well.
Old Aug 24, 2011 | 11:49 AM
Originally Posted by Graham@NitrousOutlet
This is nuts Trey!
The kit I got from you and the crew is flawless, it's when I add the box in the equation. Is larry local to the DFW area?
Old Aug 24, 2011 | 11:57 AM
Guest
Posts: n/a
Thanks, but I want you spraying that flawless kit! He is not but he is sharp guy. I shot him a PM already maybe he can shed some light on this. I am not great with wiring by any means.
Old Aug 24, 2011 | 12:04 PM
Larry @ AMS's Avatar
I hate to say it, but I would never run a 685 box again. I went thru 2 on my own car and my buddy is on his 3rd in 2 years. The most recent 685 was a week ago right out of the box and it went up in smoke.
again sorry for the bad news
Old Aug 24, 2011 | 12:06 PM
Larry, which box do you recommend? Msd has a few to chose from.
Old Aug 24, 2011 | 12:29 PM
The way I run my car is with a 6AL and N.O. Progressive Controller. I do not need any timing retard since I swap files due to being an A4 car and needing different shift points for NA v's N20.
The common box people use for an ignition box and timing retard is the MSD Digital 6. This still leaves you with needing a window switch or progressive controller.
Old Aug 24, 2011 | 01:10 PM
Guest
Posts: n/a
Thanks Larry. This is something I do not have a lot of experience with. Glad we have some guys here that do.
Old Aug 24, 2011 | 02:04 PM
no problem
Old Aug 24, 2011 | 03:07 PM
NONOS-1's Avatar
Well had one last for 3 years.. went bad.. Got new one in for 2weeks went bad number 2... Going to try another going to take it back... bull ****!
Old Aug 24, 2011 | 03:13 PM
NONOS-1's Avatar
Hell can't even get my money back.. They want me to send it in.. be 3 weeks..
Old Aug 25, 2011 | 10:06 PM
Nitro Dave's Nitrous Outlet's Avatar
Wow.. Looks like the Mallorys are having diigital 6.
Dave
