Resistor Trick question??
Old Sep 8, 2011 | 03:49 PM
azimm1984's Avatar
Default Resistor Trick question??
I know there are a ton of post about this, I am looking for the amount of timing that gets pulled per resistor, all I have found is what resistor make it xx* temp.... for say stock tune thanks
Old Sep 8, 2011 | 08:01 PM
Gary Z's Avatar
The stock 98 PCM pulls three degrees if IAT is above 55 C and MAP is above 90 kPa.
Old Sep 8, 2011 | 08:23 PM
azimm1984's Avatar
so no matter the resistor it can only pull 3*? someone said it can pull more only reason im confused
Old Sep 8, 2011 | 09:30 PM
SargeZ06's Avatar
That's without changing it in the PCM. You can pull whatever you want if you set it in the PCM.
Old Sep 8, 2011 | 09:45 PM
Revson's Avatar
And there's a table that can be done in in HP Tuners? I think?
Old Sep 9, 2011 | 01:04 AM
azimm1984's Avatar
I was hoping to be able to pull more than 3* without buying a tuner... Right now all I have is an autotap to see where my timing is. and wanted to run 150 shot... what would be my cheapest option to pull more than 3*?
Old Sep 15, 2011 | 02:04 AM
Pwebbz28's Avatar
Cheap + nitrous = BOOM!
Old Sep 15, 2011 | 04:59 AM
Jasons50's Avatar
Running a 150 shot would be safest on a dynotune. Im sure tuning cost money, but probally cheaper than replacing a engine.
Old Sep 15, 2011 | 07:28 AM
SargeZ06's Avatar
Where in Indiana are you?
Old Sep 15, 2011 | 10:22 AM
Nitro Dave's Nitrous Outlet's Avatar
Get a lingenfelter timing controller and do it right.
Dave
Old Sep 15, 2011 | 04:12 PM
SargeZ06's Avatar
Dave
So that makes the resistor mod the wrong way to do it?
Old Sep 15, 2011 | 04:28 PM
I just feel there are better ways of doing it. Just my opnion.
Dave
Old Sep 15, 2011 | 06:53 PM
SargeZ06's Avatar
Dave
What are the cons of using the resistor mod?
Old Sep 15, 2011 | 11:11 PM
azimm1984's Avatar
sarge im near indianapolis
