fuel pressure
Old Sep 13, 2011 | 08:03 PM
ls1m6nichols's Avatar
Default fuel pressure
How do I figure out my fuel pressure or are they all the same
Old Sep 13, 2011 | 09:38 PM
BlackKnight408's Avatar
Do you need to know what fuel pressure you should have (spec) or do you want to know how to test for fuel pressure?
Either way I'm sure a quick search in the appropriate section would probably answer this.
Old Sep 14, 2011 | 06:22 AM
custm2500's Avatar
Ph.D. in HUBRIS
If you need find the pressure your car is running at you need to buy or borrow a gage and it will tell you exactly.
If you are setting up a basic nitrous system you should be safe going with stock pressure and I think that is 52 psi.? A quick search will confirm that.
