Nano..Worth it?
Old Sep 26, 2011 | 09:30 AM
wreckwriter's Avatar
Originally Posted by Brad@NANO Direct
NANO is accepted in both. I am not sure of the IHRA but we do have the letter from NHRA for there approval.
I wrote IHRA tech yesterday, just got reply. Legal for brackets.
<edit> NHRA replied same.
Old Sep 26, 2011 | 06:57 PM
A guy that bracket races will need at least 2 10 lb nitrous bottles for a day of racing. Correct me if I'm wrong but that means he also needs 2 nano bottles. One would need to buy the 3000 (way too hard to get 4500 fills around here) Sport kit plus an extra bottle. Around $600 or a bit more, right? Would anything else be needed? How difficult to swap the extra bottle into the clamps and swap the hose? Maybe better to have 2 hoses?
Old Sep 26, 2011 | 08:17 PM
89pigeontoe's Avatar
Never used nano but surely it last more than one nitrous bottle? If so I don't see why u can't just swap nitrous bottles.
Old Sep 27, 2011 | 08:12 AM
Brad@NANO Direct's Avatar
It is very simple to swap NANO bottles. The black on/off that the hose attach's to is a simple hand tight valve. It is simply unscrewed and placed onto the other bottle. Yes for a bracket racer depending on number of runs and passes it would be a good idea. You would need a complete Sport kit and spare NANO bottle depending on if either of your bottle valves have gauge ports.
Old Sep 27, 2011 | 08:13 AM
It is a 1 to 1 ratio. There are other benfits for the system besides pressure and full bottle.
Old Sep 27, 2011 | 08:34 AM
AutomagicLS1's Avatar
nano works good. When I had nawwzzz on my car on the dyno you could see the shot/power was consistent throughout the entire pull and back to back pulls. Best way to describe nano if you are out street racing or at the track and one of those pesky turbo cars or big motor car wants to keep running you there will be no more waiting for that bottle to get up to pressure
Old Sep 27, 2011 | 11:53 AM
My bottles will be Nitrous Outlet, they're directly compatible with Nano so I only need a Universal kit and a spare bottle. Whats my cost on that?
Old Sep 27, 2011 | 12:47 PM
$319 for the kit.
$209 for the extra NANO bottle
$29 Extra check valve for spare NANO Bottle
$557 + shipping.
Shipping will be around $28+/-
Old Sep 27, 2011 | 01:03 PM
LSmonster's Avatar
How many 10 lb nitrous bottles will one nano bottle support before you have to refill?
Old Sep 27, 2011 | 01:12 PM
1 to 1 ratio with the nitrous bottle. You are able to use 9/10#'s in the nitrous bottle.
Old Sep 27, 2011 | 01:16 PM
LSmonster's Avatar
So just to be clear, when my 10 lb nitrous bottle is empty, I'll have to fill my nano bottle too?
J
Old Sep 27, 2011 | 01:17 PM
  #32
J
Correct. It usually costs $2-8 per fill. Scuba and paintball shops fill them.
Old Sep 27, 2011 | 05:50 PM
  #33
ls1curt's Avatar
A nano setup really doesn't cost much more than a good heater but you dont have to wait around for it to get up to temp. and you get consistent temp. throughout the run. A local paintball shop filled my 3000psi bottle for $3.
Old Sep 27, 2011 | 06:34 PM
  #34
SSmoken's Avatar
ive thought about this too joe. though cheap, heating with a torch gets old lol.
Old Sep 27, 2011 | 07:34 PM
  #35
kidcamaro98's Avatar
also been thinking about it....
Old Sep 27, 2011 | 08:44 PM
  #36
@ ssmoken, please never use a torch to heat bottles.
Old Sep 27, 2011 | 08:49 PM
  #37
223HAWK's Avatar
Why so he doesnt end up on the next fast and furious? NAWWWZZZZZZZZZZZZZZZZZZZZZ
Hes done it for years lol!
Old Sep 27, 2011 | 11:43 PM
  #38
SSmoken's Avatar
i knew that was coming hahaha! been doing it for 5 years. i know plenty of others who do it as well.
Old Sep 28, 2011 | 03:18 AM
  #39
itsslow98's Avatar
Workins great in the winter, but sucks in the summertime. Once it hits 80 or above be prepared to have ice packs on hand to put on the bottle to get the pressure down. I sold my nano 3000 kit before i ever had to refill the nano cause I simply couldnt use it in the summertime.
Old Sep 28, 2011 | 08:15 AM
  #40
Above 85+ degrees you do need to cool the bottle. If you are at the track ice works great, or the chiller pads we send with the systems work good unless it is very hot.
Usually any full nitrous bottle in 85+ temps will need to be in the shade or chilled, especially if it is inside of the car in the sun. We have been sending most systems out now with a little less pressure on the static side to help with this.
