Nano..Worth it?
Old Sep 28, 2011 | 08:45 AM
  #41
wreckwriter's Avatar
I'm concerned about the cooling too, we had several 100 degree plus track days this summer.
Old Sep 28, 2011 | 08:55 AM
  #42
Brad@NANO Direct's Avatar
On a 100+ degree days we usually leave the bottle in ice water with a cooler or 5 gallon bucket. Ice one the nitrous bottle in a zip lock works good too. By the time you get staged it will be around 65-70 degrees. A full nitrous bottle in 100+ degrees will need to be cooled whether its our system or a standard system.
Our nitrous bottle label has a temp label to keep track of the temp. Usually with the added performance and a/f being stable down track overcomes having to put ice on the bottle.
Old Sep 28, 2011 | 11:39 AM
  #43
AChotrod's Avatar
Me and Brad didnt have any issues keeping my bottle cool at the LTXShootout and it was 105* out. Just used a bag of ice/ cooler packs between rounds and a bottle blanket.
BTW I went to the track last friday to do some more testing but blew up my slip yoke first pass. Going back this friday for redemption. Ill keep ya posted on how it goes.
Old Sep 28, 2011 | 01:10 PM
  #44
cyipher's Avatar
Originally Posted by Brad@NANO Direct
Above 85+ degrees you do need to cool the bottle. If you are at the track ice works great, or the chiller pads we send with the systems work good unless it is very hot.
Usually any full nitrous bottle in 85+ temps will need to be in the shade or chilled, especially if it is inside of the car in the sun. We have been sending most systems out now with a little less pressure on the static side to help with this.
What static pressure are you shipping your units with now? and what CI are your nano bottles, do they change depeding on the kit? this would be for the 10 lb kit
Old Sep 28, 2011 | 01:36 PM
  #45
That's 85 degrees bottle surface temp, right?
Old Sep 28, 2011 | 01:39 PM
  #46
If the customer asks we have been sending them as low as 950psi. Usually we send them at about 1010psi to 1040psi.
Old Sep 28, 2011 | 01:40 PM
  #47
Yes, when the aluminum bottle as a whole reads 85 degrees. I have seen temperatures in the 90's during the day but bottle temp can be as low as 80 degrees if it is in the shade.
Old Sep 28, 2011 | 02:24 PM
  #48
BobDoLe's Avatar
it is well worth it. the issue with too much pressure can be a pain though. if you could easily purge the excess pressure, you're good to go.
goodbye pressure drops and waiting forever to heat up (waste) those last few pounds in the bottle.
Old Sep 29, 2011 | 01:09 PM
  #49
cyipher's Avatar
what size bottles are you using in in 10lb system
Old Oct 9, 2011 | 02:37 PM
  #50
1BAD98TA's Avatar
I would think if your bottle is in the spare tire well the temps would not get too high since the bottle is in the shade.. Of course you'd need to leave your windows down so the car doesnt bake inside.. Just my thought though...
One question I had, is there enough room in the spare tire well for the 3000 kit to fit with a 10lb nitrous bottle?? Anyone setup like that??
Old Oct 10, 2011 | 09:13 PM
  #51
1badzee's Avatar
It fits, you just have to get creative. You can also slip the nano bottle through one of their supplied brackets and drill a hole on the side there (hard to explain) and it will hold the bottle in place (to pass tech at a track). Otherwise, the nitrous bottle holds it in place because it is pushing down on it (like you can see in the picture).
I love my NANO kit and their customer service is top notch. I have called a few times with questions and concerns and they always seem willing to help. Also, consistent pressure is a beautiful thing
Old Oct 11, 2011 | 10:11 PM
  #52
GMMillwright's Avatar
A bit off topic, but does NANO re-certify the bottles? Bought mine in Oct of '06. Went to get it filled at the local paint ball place that always fills it. Guy looked at the label and said he had to check something. Turns out the certification expires every 3 years, not 5 like he thought. Local welding shop does the re-cert's too. Just curious as to cost, etc.
Old Oct 12, 2011 | 08:30 AM
  #53
Send it in to me. It is $24 from us to have the bottles re-certified. We are able to get the regulator out. A lot of places have trouble doing this. Also while the bottle is over getting hydrotested i inspect and replace all of the o-rings in the bottle for you.
Shoot me a pm and let me know if you want go this route.
Old Oct 12, 2011 | 09:14 AM
  #54
I'll send it to you this week, Brad. Thanks for the quick response.
Old Oct 12, 2011 | 10:23 AM
  #55
gi8e7oi825's Avatar
So I kind of want a NANO system too, but it seems like it's plagued with the same problems that nitrous bottles are: temperature. Is there NO way to fix that, so even in 120°F temps I won't have to bath things in ice water or fan them off??? Does NANO only use a single regulator?
Old Oct 12, 2011 | 02:02 PM
  #56
1badzee's Avatar
Most convenient thing to do is bring a small cooler with you at the track with some dry ice and keep one or two ice-packs with you (the gel-filled things you would use to ice an injury or something). Just place them on the bottle for a few minutes before a run and you will be fine. This is all assuming the conditions get THAT bad (heat-wise) in your car. I just so happen to use it at night every time so temperatures aren't terrible.
Old Oct 12, 2011 | 09:45 PM
  #57
94FBIRD's Avatar
I keep a bottle of water in my ice chest at the track. I'll pour a bit onto a towel, ring it out and lay it on the bottle if it gets to hot. Super easy.
Old Oct 13, 2011 | 01:20 AM
  #58
Dragman's Avatar
This work real good
