Nitrous problem
Old Sep 20, 2011 | 09:16 PM
Blastin's Avatar
Default Nitrous problem
I have a 02 T/A with lid, no screen in maf and smooth bellow. The car runs fine on motor and didnt have a problem on spray till I hooked my NANO kit up. I am not saying it is the NANO KITS fault but it just started happening. All that has been changed is i stopped the fuel leak I had and went from 3" to 3" to a 3" to 4" and had the NANO valve put in my bottle. Every time I spray the car falls on its face or sputters and pops and I have went through all the lines and wires and it sprays fine seems like when I had the fogger out Fuel seems to be ok but im not sure and I have no gauge. I am running TR6 @ .35 not sure whats going on it was fine then wont run right the fogger is right before my maf if it helps any.
Old Sep 21, 2011 | 08:03 AM
89pigeontoe's Avatar
Sounds like its going really rich. Never heard a whole lot of good out of the nano kits. Did you pull a plug? Or have a wideband. I believe they usually recommend a jet change when going nano don't they?
Old Sep 21, 2011 | 08:18 AM
Brad@NANO Direct's Avatar
When did you buy your system? Which system did you purchase? Did you purchase from us or a dealer? Did you change your fuel jet? You may have been rich before you added the NANO.
Are you pulling any timing?
You will also need to switch to a br7ef plug @.032-.034.
If you could give me a call at the shop 785-331-2390. I can help you run through your nitrous system to find the issue.
