Went from single fogger to Nitrous outlet plate!
Well I've been wanting to add a second stage to my fogger nozzle and decided to just buy the Nitrous Outlet dual stage plate. Dang the plate works so much better then my fogger nozzle, hits instant and harder at less hp.
best pass on nozzle was: 1/8th mile
7.428 @ 93.96 1.707 60' 125hp nozzle 55n 35f
7.329 @ 99.06 1.827 60' 100 plate (mucho potential) 52n 33f
this is on a G60 15 dirt track tire. yes I can run a 8" slick but I have a certain look I'm looking for (sleeper)
this was at Street Heat event with no track prep (for street cars, dont even water the box most of the time)
my best n/a pass was
7.588 @87.28 1.684 60' with a .002 reation time
cant believe I picked up 12mph in 1/8th mile on a 100 shot and not even using the second stage yet.
Picked up 5mph over the fogger nozzle on less hp.
When I got my Nitrous outlet plate a while back, I couldnt believe the difference. I picked up 6 mph in the 1/8 over a fogger nozzle with less jet. Went from 107 to 112mph out of the box on a .078 jet. and my car never hooked anymore even off footbrake from 2500rpm. I'm gonna need some suspension adjustments or a delay to hook on my new motor now for sure
my next step is setting up my 1 gallon stand alone that I have. Going to run race gas on the nitrous. Then I'll be able to use my second stage It will be low pressure 10psi fuel. Just have to find the conversion for the jets.
