quick question
Old Sep 27, 2011 | 10:15 AM
71 chevy's Avatar
Default quick question
im planning to install a DRY nitrous kit to help turbo spooling at the line.
I would like it to be able to spray up to a 200 shot, in case I need to set it on kill and spray the whole pass.
i have a vic jr intake with a 4bbl throttle body
here is the question
**should i go with a plate under the throttle body, or should i go with a nozzle in the intake piping somewhere
Old Sep 27, 2011 | 01:21 PM
Brad@NANO Direct's Avatar
I would contact Nitrous Outlet about their spray bar setup. Just like a plate but built into the intake right below your throttle body. The reason is they place the holes in the bars to spray right into each cylinder.
https://ls1tech.com/forums/nitrous-o...s-who-has.html
Old Oct 6, 2011 | 04:57 PM
Chris@NitroDaves
Guest
Posts: n/a
If you wanted the best distribution possible then as Brad said i'd send the intake to us so we can install spraybars in the manifold. We basically turn your entire manifold into a nitrous plate. I can set you into an entire kit for around $720 with a 10lb bottle and if you are pairing it with an existing setup we can do the bar's for $300.
Old Oct 6, 2011 | 10:27 PM
71 chevy's Avatar
thanks guys ive decided to keep it simple and do a nitrous only fogger in the intake piping
