Single plane with spray bars? Who has it?
Im suprised you have not had any good responces here. There are a good number of people on this site with our spray bars. So I will bump this to see if you can get some customer feed back...
I have personaly used them in my own cars and the car I am about to start tuning has them as well.
Dave
Dave
Plates aren't big enough and i already have a DP
Spray bars in the intake keep from adding another 1/2 inch to the overall height of your setup as well. Dave says they flow the system after installing the bars as well. I want to hit the motor with 100-150 on the bars out of the hole and then go to the 300 from the direct port.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
With our spray bars we are able to put the discharge point down in the intake plenum. As a result we are able to minipulate the distribution pattern to each cylinder better than we would be able to using a plate bolted up top.
Spark plugs are what tell you if something works our not. Our custom spray bars work very well.
Dave
I am going with a Nitrous Pro flow single spray bar plate. as I run a 4500 TB, they make a nice 4150 to 4500 adapter with the bars built into the adapter. I just got it today from the UPS man, and going to be installing for LSFest.
So I cant say for sure how it works, but My engine builder have had several cars do very well with this style plate...
I am also going to be pulling off the rails, using a bypass style regulator to get the pressure down to 7lbs so we can get the tune spot on. seemed kinda hard to make small adjustments on my other car with 58lbs of fuel pressure, or it could of been the style of the nitrous kit, but not for sure...
Our normal turn around time is around two weeks. However it depends on how many intakes arrive before yours.
We can do just the spray bars and provide the jets or we can provide the complete system.
Dave
