Can nitrous guys show a little love for an m6?
I don't post to often on here but I thought I would share my latest trip to the track.
I am really close to the coveted 9 sec pass...
here is the vid.
http://www.youtube.com/watch?v=1pPuS...&feature=share
basic set up:
trex v2 cam
stock rods/pistons/heads
good valve springs
pacesetter headers
stock ls6 mani
frankenstiened n20 kit that i pieced together
150 pills
t56
textralia twin disk
moser 9in with 4.30's
afco rear shocks
strange coilovers up front
here is a pic after i got the tubing bent I dont have any finished pics oddly enough
here is the vid.
basic set up:
trex v2 cam
good valve springs
pacesetter headers
stock ls6 mani
150 pills
t56
textralia twin disk
afco rear shocks
thanks! I am going to try and get the 9 with the 150, just have to dial the suspension in a bit more. I will be looking for a bit of tuning help when I start increasing jet size. Right now I am around 24 degrees of timing from an na tune with 28 degrees max and afr is around 12.2 does this sound about on par for a 150 to you guys? I normally mix 112 half and half with pump gas to provide a bit of safety.
I have a 2 step I just haven't really thought out how to use it with the nitrous. I have my n20 set up on a wot, and an msd window switch.
as for weight, it is a stripper car, and I have removed the ac/ps and put light weight carpet in it. It still has the factory seats. I am not really sure on weight if I had to guess I would say a tad over 3000 with out me in it.
Ren, very impressive performance. I like your “frankenstein” system. My best is 10.78 sec @ 129 mph with a dry 125-shot. I’m wondering why you are so much quicker than me. Obviously you shift quicker but I’m surprised by the difference. I also have 4.30 rear gears. I need bigger tires. With 26-inch tires I'm at 7100 rpm in the lights.
http://www.youtube.com/watch?v=GtHY85vsH9k
I can't really explain it other than my cam might like the n2o a bit better, I have run 26 in slicks for 3 years on my car up until this last outing. I made the switch only out of neccesity. My car does mph 122-123 NA but that was on the nitrous timing so I expect another mph or so out of it with an na tune.
Looks like you should really try and get the 60ft down. I have been in the high 1.4x's on motor before. Madman can get you going in that regard, they helped me big time!
Edit: also I dont know what launch rpm you are at. But I leave at around 7-7200 na and 6k with n2o
Damn Im thinkin this winter I may do 4:30s if your crossing at 6800-7000! Im around 6200 lol
Im still on a 100 shot too..Sick car fosho!! I need to lighten mine up (3700lbs) but I like A/C too much lol
Congrats man!
Congrats man!
