How often you change plugs?
Seems to me running a BR7 and most the time not spraying dirties up the plugs pretty fast over a NA gapped plug.
If your at 125 or below, you can run a tr6 plug and I have gotten 8,000 miles out of quite a few sets.
You just have to watch your timing.
Now, most people here will start bashing on the tr6 plugs right away, as it is a projected tip plug.
But, if you look into the LS-1 tech archives, you will probably be surprised to find that tr6 plugs have been used for smaller nitrous shots since this site has been started.
If your hitting it with a 150 or above, then the tr6's are not for you.
For $20, I have a hard time not changing them often.
Unless you are talking tiny tiny kits??
You will run quicker with a little more heat on nuts then a N2O plug.
When I walk in and get a new guy at the store they always think I'm joking or a nut when I order 50 at a time.
