Fuel pressure drop, how much is ok?
Old Oct 22, 2011 | 08:20 PM
ducatisl's Avatar
Default Fuel pressure drop, how much is ok?
Okay, I've been approaching nitrous with baby steps. I was at a 1/2-mile event where I ended up running all-motor because I decided to log fuel pressure and saw, without spray, that pump pressure would drop to 51 psi pretty consistently.
So when should I start to worry?
Old Nov 1, 2011 | 05:08 PM
Chris@NitroDaves
Guest
Posts: n/a
That's around a normal drop for a car with mods in most cases. Anything lower than 45-47PSI and it doesn't immediately recover pressure then I would look at possibly starting to upgrade the pump or get a boost a pump of some sort.
Old Nov 1, 2011 | 06:52 PM
ducatisl's Avatar
Thanks Chris, guess I'm just a little nervous about pulling fuel from the rail when pressure is falling to begin with. Guess my winter project will involve deciding between a standalone or a new fuel hat..ugh. This is what the fuel pressure does:
