Problems with MSD Window Switch
Old Oct 23, 2011 | 10:01 PM
03EBZ06's Avatar
Default Problems with MSD Window Switch
Switch I'm referencing:
http://www.msdignition.com/Products/...ow_Switch.aspx
When first intalled, it worked. Now, there is NO GROUND SIGNAL to the yellow wire. Setting were Cyl=4, 3500-6800. In fact, there is battery voltage from that wire. Is that normal?
Which window switch would you use? Looks like I need a new one.
Old Nov 1, 2011 | 05:10 PM
Chris@NitroDaves
Guest
Posts: n/a
No thats not normal and it sounds like something with the ground circut in the box went bad.
We have had good luck with these http://www.nitrousoutlet.com/catalog...2&product=4488
Old Nov 1, 2011 | 08:25 PM
03EBZ06's Avatar
Thanks. I've already installed and tested the 15974 progressive controller. I am very impressed w/the product. The little handheld is awesome, just gotta figure out the ramp setup to make it work for me.
MSD is on the way back to MSD for repair.
