NOS Progressive Controller Settings
Old Oct 30, 2011 | 01:34 PM
03EBZ06's Avatar
Default NOS Progressive Controller Settings
1. What is the cylinder setting supposed to be set to? Mine is at 04 and appears to be working ok.
2. Regarding the Ramp Rate. I am trying to find a good
ramp setup for this device and a 6 speed. I tried the following yesterday:
It helped a little. Note, the device activates the ramp when WOT is achieved via TPS.
1 Delay: 0
2. Start Rate : 10%
3. End Rate : 100%
4. Ramp Time : 1 second.
5. Pause Mode : Resume
more curious if some of you have experimented with this and what you ended up with.
Old Oct 30, 2011 | 02:49 PM
batboy's Avatar
I just recently installed a progressive controller. Was previously using a window switch. I asked this same question and got hardly any response. How big of a shot are you using? I knew a 100 shot was okay without the controller, but I was breaking the tires loose with a 150 shot when it kicked in. So, I set my start rate at 66%, end rate 100%, and ramp time 1 second. That seemed to work fine for my car. If I jet up to a 175 shot, I might try a start rate of 50%.
Old Oct 30, 2011 | 04:09 PM
03EBZ06's Avatar
125 shot. Thanks for the info. It murders the tires to a point I have to let off briefly and get back in it. I think its a matter of me finding the exact time when it gets loose then I can probably work around it.
When you ramp up, are you starting as soon as you hit WOT?
Old Oct 30, 2011 | 05:07 PM
WheelsUp84z's Avatar
I would put a .4 or so delay on it, and start the ramp at 30-40%, same ramp time. That way you can get out of the hole a little bit before you are on the nitrous, and it will hit it a little harder once you have traction.
Old Oct 30, 2011 | 09:49 PM
batboy's Avatar
Mine activates at WOT and above 3,000 rpm. I see you have a stroker, no wonder. I concur with the delay and maybe even start at 0%.
