nx express intake
Old Dec 5, 2011 | 11:12 AM
like2z28's Avatar
Default nx express intake
does anybody have any info on a nx express ls1 intake good or bad?I have a chance to pickup one cheap but can't find anything about them . This one has the throttle body on it and is drilled for 2 fogger kits ,anything good bad or ugly would help ,is there anybody who have one in use or any info on this part thanks
Old Dec 5, 2011 | 11:39 AM
camscam02's Avatar
Im pretty sure they don't make intakes... you may have another manufactures say FAST or maybe a stock Ls6 intake with a Nitrous Express direct port??
Old Dec 5, 2011 | 01:16 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
we had an ls1 intake at one time, but there are very few, is it an aluminum intake? if not then its not an NX brand intake...only problem we had was heat soak, which isn't a problem when you are spraying, but when running NA it heat soaks
Old Dec 5, 2011 | 06:40 PM
like2z28's Avatar
Default nx intake
yeah it's aluminum and has nx nitrous cast into the top and a 85mm throttle body ,it's has twin ports drilled for two kits ,anything as far as info ?good bad ???
Old Dec 5, 2011 | 08:15 PM
99slobird's Avatar
I had one with nx fuel rails solonoids that mounted on the side of the rails and nx tb, if I remember correctly I was told by one of the guys at nx that if I was planning on spraying more than a 150 that that setup was probably not for me. It looked awesome but I never sprayed it. He said that the intake was based off the ls6
Old Dec 6, 2011 | 09:14 AM
the only drawbacks are heat soak and weight, it flowed a little better than a ls6 intake,and we tested it up to 250hp nitrous jetting and it worked fine
Old Dec 6, 2011 | 05:26 PM
like2z28's Avatar
Default nx intake
thanks for the responses ,nx guy do you guys sell everything I need to get this setup going and pre tuned
Old Dec 6, 2011 | 06:44 PM
99slobird's Avatar
Put a pic of it up..... I would like to see what your setup looks like
Old Dec 7, 2011 | 06:13 AM
a4ls2goat's Avatar
Pics??
Old Dec 7, 2011 | 11:03 AM
yes we do!!
Old Dec 7, 2011 | 01:18 PM
99slobird's Avatar
Yea that's different than the kit I had...... Very clean Mine was a black soft line kit
