Fuel pump for 200 shot?
Old Nov 28, 2001 | 10:24 PM
Slick T/A's Avatar
Default Fuel pump for 200 shot?
Right now I have a thunder 224 cam, PY3600E conv, LS6 mass and intake, Mac headers with ORP, Custom programming, race built tranny that is on its last leg, 3:73 gears, T/A stud and girdle kit, cut-out, 150 shot Nitrous Express kit. On motor I am pushing 367 horsepower. I am wanting toknow if there is a bigger pump than the Walbro 340 it claims to only be able to support 500 rear wheel horsepower. I am leary of running lean so I need to now what I should do to take care of it. By the way the nitrous kit is a wet kit. Do you think I will need a booster pump as well. I also need information about drilling out the restriction in the fuel line. Where is it at? Please give all the information you can think of. In case your wondering the current set-up has only been ran one time with a full pass of nitrous. It ran 11.18 at 121.51 with a 1.601 sixty foot. Thanks for all the help and SORRY THIS IS SO LONG. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 29, 2001 | 07:42 AM
RyanJ's Avatar
SSU Moderator
Default Re: Fuel pump for 200 shot?
if your worried, autotap. if you go a bit lean on the top end add an inline pump to be safe.
Ryan
Old Nov 29, 2001 | 08:49 PM
Slick T/A's Avatar
TTT
Old Dec 1, 2001 | 10:34 AM
10SECSS's Avatar
I have run the NX 200 shot with the stock 98 fuel pump and injectors. Only sprayed about 2 bottles worth with that shot. In comparison, I put down 506 at the wheels with the 150 shot and have done that for almost 10,000 miles with very liberal use of the gas. <img src="images/icons/smile.gif" border="0">
