anyone with a dedicated low pressure fuel system for a single shark nozzle
please let me know what you have- I know you would have to jet it differently for a low pressure system - I have a shark nozzle.btw
I have the exact set up . Jaz 1 gallon fuel cell, Product engineering PE 4200 pump and filter, Holley regulator, 8an lines to the reg and 6 from reg to the solenoid....3an return line with a small jet from the solenoid to the fuel cell. I run mine at 10psi and it seems to work great.
Matt
do you have a jet list for a 150/200/250 shot? I'm sure they are quite a bit different since it's low pressure(10psi) vice high pressure
Use this calculator it is dead on. http://cosmik.org/calculators.htm
Matt
