need help with nitrous oxide
Old Jan 23, 2012 | 04:40 PM
MR.Mean's Avatar
Default need help with nitrous oxide
hey everybody i need help with nitrous oxide i have a 1994 LT1 Z28 camaro with a 350 small block cammed and with ported heads im thinking of adding nitrous but i have no idea how big of shot i can make it with out my motor blowing up if you guys can help me it would be awsome thanks
Old Jan 23, 2012 | 04:47 PM
warriorcustoms's Avatar
a stock piston is 150 shot MAX If you wanna spray more you have to get nitrous pistons You will need to upgrade your fuel pump too Nitrous Outlet or Nitrous Express both have good kits & good Tech guys
Old Jan 23, 2012 | 05:30 PM
MR.Mean's Avatar
so 150 is the max shot i can put in my car?
Old Jan 23, 2012 | 05:51 PM
karpetcm's Avatar
I ran a 150 shot wet on my 93 LT1 full bolt ons. You have more work done then i did on mine so you might need to upgrade injectors and pump. I ran it with a adjustable fuel pressure regualtor AFPR and the car ran fine from 168-228k miles and zero problems. I did have a good tune and ofcourse nitrous plugs.
