Anyone with an MSD window switch Need ur Help
There are 2 small wires sticking out from the side of the unit that form 2 little loops. You have to cut these. The reason is, the LS1 spark system is set up like that of a 4-cylinder. The signal coming from your tach feed will only work if you set up the MSD window switch in "4-cylinder" mode. Try this and it'll work just fine.
Reckless => You are da man....thanks <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
