What kind of system to go with
Old Jan 24, 2012 | 07:49 PM
06SpiceRed's Avatar
Default What kind of system to go with
Thinking of putting a 150 shot on my 06 m6 gto and I was wondering what system to get and should I go with direct port ? Also what's the benefit of having direct port ?
Old Jan 25, 2012 | 10:25 AM
87silverbullet's Avatar
You don't need a DP for a 150 shot. Just get a plate kit so that if you want to shoot more the plate will be able to handle it. Nozzles are a pain in the *** don't even go that route. Ask me how I know.
Old Jan 25, 2012 | 11:08 AM
Phantom's Avatar
Get with the guys at nitrous outlet. Great product and even better customer service. I run one of their plates and it's awesome
Old Jan 25, 2012 | 03:24 PM
tittan1500's Avatar
Nozzles are not a pain in the ***, you can spray 150 on a nozzle easy, a plate is better for when you want to spray more,
That being said, you can still spray more on a nozzle but you need to the the plugs tell you what the engine is doing.
Old Jan 25, 2012 | 04:12 PM
Nitro Dave's Nitrous Outlet's Avatar
Like stated above our single nozzle system or our plate system would be fine for 150 shot. Now if you just like the killer look of one of our directports thats fine as well. However a directport at that level is a bit of over kill.
Dave
Old Jan 25, 2012 | 08:17 PM
06SpiceRed's Avatar
Dave
So who do I need to call and ask for tomorrow?
Old Jan 26, 2012 | 08:09 AM
When you have to make a hole in your intake boot its a PITA. When the nozzle keeps turning no matter what you try to do to stop it (loctite)its a PITA. I don't have none of those issues anymore with the 2 stage plate I used to get rid of my 2 nozzle setup.
Old Jan 29, 2012 | 03:57 PM
red fury's Avatar
Consider a dry kit and the halo ring
Old Jan 29, 2012 | 04:00 PM
SCott5's Avatar
Nitrous Outlet.
Old Jan 29, 2012 | 04:59 PM
06SpiceRed's Avatar
I ended up going with the nitrous outlet total package kit! Can't wait to get it installed
Old Jan 29, 2012 | 07:28 PM
Cape T/A's Avatar
good choice.
Old Jan 29, 2012 | 08:45 PM
Sales1@Texas-speed's Avatar
Great choice. The products and services from Nitrous Outlet are top notch!
Old Feb 1, 2012 | 09:23 PM
Frans96SS's Avatar
Dave
This is the kit that i just ordered from you dave.
Old Feb 2, 2012 | 12:51 PM
ROMERO98Z28's Avatar
how much does it cost?kit
Old Feb 6, 2012 | 07:34 PM
slippi84's Avatar
Money is the only limiting factor when trying to spray a 150 shot. Def NEGGATIVE on dry kits for that much nitrous though. If you have the money DP is def the coolest and safest way to go because you know that every cylinder is getting the same amount of fuel and nitrous but in my opinion anything under 250 shot a plate is the way to go anything over DP
Old Feb 6, 2012 | 08:12 PM
PONTIAC SLP's Avatar
For 150hp it's not recommended for Direct port system , For that shot you need plate or dual foggers system .
If you're planning for 300 or more i would say do the Direct port system
Old Feb 8, 2012 | 08:32 PM
tittan1500's Avatar
I have had no issues withe the nozzle moving using the N20 outlet supplied fastener. I did use a little blue thread lock to be safe.
Old Feb 8, 2012 | 08:57 PM
slippi84's Avatar
I've never been a fan or thought putting a nozzle in silicone or rubber coupler was a good idea. I think nozzles are fine just putting them in a coupler worries me. Put it in the pipe if you can and call it a day. I still think that a plate kit with pricing what it is, is a much better option.
