Any reason I can't do this....
I can't think of any reason the engine would be damaged from hitting 1 bank before the other. Any thoughts out there?
You don't think it will cause problems that your direct port nitrous injection is only injecting nitrous into 4 of 8 holes?
There are lots of setups out there using timers too spray 4 out of 8 to start and then the 8. Makes for a low cost controller and works great. The only ones I know of are doing it on opposing cylinders. I can't think of any reason why it can't be done on 1 bank at the time.
You'll be alot better off to just use the controller.
And start off a little smaller than 400.
Just sayin.
I'd get a controller like the NLR NMS-1000 that can ramp the first half in, flat line that first half of the shot after it reaches the amount you want, and then ramp the rest of it in fully.
Dave
