need some advice from the experts
2nd thing, i plan to hit this motor with a 300 hit or so, will e85 support that?
The reason I am asking these questions is the car is already tuned for e 85 and has a standalone of which the previous owner put e 85 in there as well and if the e85 is the better choice it will save me the trouble of tuning it back to utilize pump gas in the main tank. will i have a better tuning window with e 85, or 93 with c16 in the standalone (I know you guys will tell me not to hit it with that much on 93)
in case you want some motor info, it is a 408 with ~12.4-1 comp.
Thanks for any input!
Thanks atv i will give him a call shortly
also what has me concerned is my back pumps are twin walboro 255 pumps will these be ok on 85 or will it burn the pumps up?
Dave by all means step in if i got any of that wrong.
The holley black may be ok. With E85 it is really important to look the intire system over due to the amount of volume that has to be moved.
Fuel pump
Fuel pressure
line size
fitting orfice
solenoid orfice
inner plate or nozzle orfice
I am currently working on the flow bench with a set up that ran into an issue of not being able to flow enough fuel at 6 psi to support a 300 hp tune up. So I jacked it up to 13psi and it flowed enough to get the power levels I need.
Now the issue with this is my flow bench has a very short fuel line. No in lkine filter etc. Much less drag than a car that has a fuel pump in the back.
So to make sure this customer has no issues I am swaping him to a 45psi set up and re flowing everything. This means his Holley black is not going to cut it.
Dave
As to the tan color not so much. I would say look for an oxidized look. Dull Silver.
Dave
Dave
Ok dave i'm confused, the one picture of the plug you sent the fuel ring was a half turn and was greyish/silver and the remaining half was a tanish color and this was a "soft" tuneup
the second plug was "oxidized" a full turn and this was an aggressive tuneup......I want to find a happy meadium between the two correct?
so the plug should be grey/silverish 3/4 of a turn what will the remaining 1/4 be if you say it should be oxidized to me that is the same color as the rest of the plug?? Sorry if i sound confusing lol
