Is it worth changing from a ms4 to a ms3??
Old Mar 3, 2012 | 12:10 PM
n2ols1cam's Avatar
thanks man, ill give them a call.
Old Mar 3, 2012 | 12:23 PM
Yullose's Avatar
Can anyone comment if there are any PTV clearance issues with the MS3 or 4 in an otherwise stock LS2 with 243's ? I see the MS4 is up at .649 on the intake. Wasn't sure if that required flycutting or not.
Sorry if I'm hijacking.
Old Mar 3, 2012 | 02:36 PM
n2ols1cam's Avatar
when i had a stock bottom end i had my 243 heads milled .30 and i never had a clearence issue. you should be just fine.
Old Mar 3, 2012 | 03:34 PM
Yullose's Avatar
Which did you have ? MS3 or 4?
Old Mar 3, 2012 | 09:45 PM
n2ols1cam's Avatar
the ms4. ive never had a ms3 in my car yet.
Old Mar 3, 2012 | 10:27 PM
Fbodyjunkie06's Avatar
Originally Posted by BOBS99SS
i didnt read the whole thread, my phone wont load but on that big of a shot you should be thinking custom grind, imo the ms4 is better than the ms3 , but custom grind spray cam is what you should look ito, eps ftw
Why would you choose the MS4 over the MS3, what do you think makes it better than the MS3?
