Wiring diagram for LNC-002 and NOS mini controller
1 Post
I drew this up for a friend running these two, basicly to help his install go a little smoother. The Lingenfelter LNC-002 is a launch controller and timing retarder, and the NOS mini controller is a dual stage progressive nitrous controller. I feel pretty confident that this is drawn up correctly. But any questions or comments are welcome!
![](http://i205.photobucket.com/albums/bb10/Bigfoot76/NitrouswiringforNOSminicontrollerandLNC-002Finaldraft.jpg)
1 Post
no, the 15 amp fuse is powering the purge button and bottle heater switch, since the bottle heater switch basicly has no load on it because its using a relay I felt there is no need to run another circuit for just the heater switch.
Do you have a diagram of how you wired yours up? I think all I need though is the terminal strip. I don't need the fuses I don't think, I know it's a good idea, but, I think the terminal strip will do what I need it to.
I have everything you do except I have the nitrous outlet window switch with no solenoid driver. I have a heater and a nitrous outlet switch panel, but I won't be using the remote bottle opener switch, just purge, arm and the heater switch. I'm not using a microswitch either, using the window switch for that.
1 Post
Second pic down is the diagram, Im using the same nos mini progressive controller.
https://ls1tech.com/forums/nitrous-o...y-nitrous.html
Mine is wired up using a bottle opener switch to operate my electric cutout.
Cape T/A do you have an under hood shot of how you ran your wires?
I am going to loom my under-hood wires, but since you do such nice work I'd like to see if I can steal anymore ideas from you while I can![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I wasn't really understanding the terminal strip AND fuse block and how you had it wired up, but it makes sense now and I will use both on mine. One for ground and one for 12v.
Now I just need to go spend 7 bucks a pop on another roll of 16 gauge wire, 12 gauge and 8 gauge to go with my 18 gauge I have that I now see is inadequate for most of my wiring especially the solenoids.
1 Post
Not much to see under the hood, most of my wires are tucked. or ran behind the engine. The wires come into the engine bay behind the computer through an existing gromet.
And yes, the terminal strip was used for my grounds, there is a jumper between all the terminals.
![](http://i205.photobucket.com/albums/bb10/Bigfoot76/Trans%20Am%20build/DSCN1742.jpg)
1 Post
I honestly dont remember the jet #'s, but it added 190 RWHP on the dyno. They rate shot sizes by engine HP and I was told by texas speed that mine is actually about a 225hp shot.
