Squirting a 75 shot with a Vig 3600??
Old Jan 13, 2002 | 07:47 PM
Kenny H's Avatar
Default Squirting a 75 shot with a Vig 3600??
Soon I will add a Vig 3600 convertor and mac headers. With that combo I hope/expect to go 11.7s @ 114-115 MPH. I'm thinking of adding a small shot in the spring, just a 75 shot. If I squirted just at the top of 1st gear and all through 2nd and 3rd, how much would that help me? I don't want to squirt right off the line because of the rear. Would the Vig 3600 convertor be an ok match with that? Of course I will be on ET streets. Would a 75 shot be enough to get me into the 11.3 @ 119 MPH range?
Old Jan 14, 2002 | 11:18 AM
Matt98SS's Avatar
Default Re: Squirting a 75 shot with a Vig 3600??
I had the 85 hp jets with the 3600 vigilante and it flashed real high but then again you said you were not gonna do it till top of 1st. I had a problem at times getting it to shift right so I used a window switch to turn it off before the shift. that converter was a bit too big for nitrous IMO
