Need educated opinions inside please !!!!!!
Just an FYI, currently the car is seeing max timing of 22.5* and AF on the 100 shot was 12.0:1. Give me some insight as to my chances of all my pistons living through a TNT 150.
BTw, I have a Ram VDS clutch so Im not concerned with the drivetrain at this point, just my bottom end. TIA
I would say if you keep the bottle pressure low at like 900psi your chances will be good.
Hard to say how much power these engines will take.
Looks like they take alot though <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
<strong>Come on now Ron...isn't that compression closer to 11.5:1? <img src="gr_emb.gif" border="0">
Chris G</strong><hr></blockquote>
Actually stock heads milled .030 and the cam. Its 11.2:1 I dont think .3 compression would make a huge difference anyway in the question Im asking.
- Matt
<strong>Well, all I can say is that in a few months, I fully intend to find out, as I am going heads/nitrous cam/200-250 shot on stock internals. Shooting for 600+ rwhp. Ask me then. <img src="gr_images/icons/wink.gif" border="0">
- Matt</strong><hr></blockquote>
I get first ride
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Keep us posted on how many runs you get,before BOOM <img src="gr_eek2.gif" border="0">
<strong>your peripherals may keep up (fuel, timing control) BUT the bottom end will not. i feel you are riding a VERY VERY thin line with that much (700+) torque already. i have tore down quite a few nitrous motors to find the stock rod bearings showing tons of copper due to this amount of torque being applied so harshly. this will cause failure if the bearings spin onto each other. sometimes catastrophic failure, like the rod cap coming off. real bad. if i were you, i would start planning rebuilding the bottom end soon. dont wait till failure. Stock rods arent good for those kind of #'s either. what kind of times are you running? are you using drag tires? this makes a difference as well as to how much punishment the motor will take. bearings get trashed faster when using big tires and big sticky clutches.</strong><hr></blockquote>
I was thinking along the same lines. Just wanted to hear some opinions. I ran the 100 jets yesterday. Ran an 11.02@127 on ET streets. I think a rebuild is in my near future. Im just debating on what route I want to go. Thanx man.
