Fuel pressure with 150 wet
Old Jan 27, 2002 | 04:19 PM
Guest
Guest
Posts: n/a
Default Fuel pressure with 150 wet
I have a Nx 150 kit on a 99 Formula.When I run on motor my fuel pressure drops to 52psi when I run on the spray it drops to 48psi and the car surges.My bottle pressure is at 1000psi.Any idea why it surges?
thanks Steve
Old Jan 27, 2002 | 06:59 PM
love2xlr8's Avatar
Default Re: Fuel pressure with 150 wet
Do you have a FPSS? If so is it adjusted correctly?
If you post a sig we could see your mods. <img src="images/icons/confused.gif" border="0">
Old Jan 27, 2002 | 08:37 PM
Guest
Guest
Posts: n/a
I don`t have a fuel pressure safety switch.Does that fuel pressure sound about right?
Old Jan 27, 2002 | 09:12 PM
Slowhawk's Avatar
LS1Tech Sponsor
Have you tried a smaller shot?
The surge could be the fuel pressure.For that big of a shot,I would have bottle pressure at 900psi.
Also you should run it on a Dyno to get A/F ratios.
Old Jan 28, 2002 | 01:21 PM
Guest
Guest
Posts: n/a
It doesn`t surge with a 100hp shot.I also have a cam do you think that matters.
Old Jan 28, 2002 | 11:00 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would try a run with bottle pressure at 800psi with the 150 jets.It sounds like you might be running out of pump or with the high bottle pressure your going too lean.
Old Jan 29, 2002 | 12:13 AM
love2xlr8's Avatar
anyone know what the factory fuel pressure is for a 99?
Old Jan 29, 2002 | 08:55 AM
Fireball's Avatar
48 psi is too low....get a fuel pump <img src="gr_stretch.gif" border="0">
