Injector size?
Old Apr 15, 2012 | 02:36 PM
tmoney223's Avatar
Default Injector size?
My set up is this
6.0L .030 over
Fast 102/102
Big cam
Walbro 255 pump
And a wet plate kit from nitrous express
I wanna spray a 250 shot and Texas speed gave me fast 36lb injectors. Will I be ok with these or do I need bigger injectors?
Thanks.
Old Apr 15, 2012 | 04:15 PM
zacht's Avatar
injectors size plays a bigger role when its a dry kit. i think you will be fine with the 36's. whats the duty cycle right now???
Old Apr 15, 2012 | 05:12 PM
BigBirdLS1's Avatar
A wet kit is really more dependent on your fuel pump/pressure.
A dry kit is more dependent on your Injectors.
Old Apr 15, 2012 | 05:25 PM
tmoney223's Avatar
I haven't installed anything yet. My LS1 is still
In the car. The pump says it's pumps 43.5 psi.
Old Apr 15, 2012 | 09:20 PM
zacht's Avatar
43.5 psi at idle??? shouldnt it be 55-58?
Old Apr 16, 2012 | 12:39 AM
tmoney223's Avatar
Lol I'm not sure that's what the box says.
Old Apr 16, 2012 | 09:53 AM
Neal@NitrousOutlet's Avatar
Your injectors are going to be fine since the wet shot uses the fuel solenoid and jets to control the nitrous to fuel mixture. There is one concern that i would like to bring up.
My thinking is that you are going to run out of fuel pump on your set up especially with a 250 shot. You will probably be wanting to run a dedicated fuel system on this setup for the nitrous or you could redo your fuel system front to back. The most cost effective fix would be a dedicated.
Old Apr 16, 2012 | 04:19 PM
tmoney223's Avatar
Ok thank you very much that's exactly what I wanted to hear.
