Another satisfied N20 outlet customer!
Busco beach is redneck heaven, I wouldnt suggest it. Uwharrie is exponentially better, and WAY bigger.
Junkie- I've got about 3 months left here in afghan, then I'll be back. Due to time constraints I'm just gonna run the **** out of the stock motor on E-85....We can be the slow SSB cars is RS275![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
You won't find the amount of trails and room to roam anywhere north of gulches but at Uwharrie.
LOL JK
I hope we can have some fun with this, because I'm pretty sure between me, you and the guy with the build below on the page before will be swapping the record back and forth this year several times.
I think you having 50 more rwhp than me will balance out the weight difference.
I've got something planned for that though
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I always have been to Uwharrie. Uwharrie is nationally accredited and known that's why I never considered anywhere else.
When I lived in SC we always went to Gulches.
I'd like to figure out how to wire my transbrake(works off 12v), my two step(works off ground) and my two step interrupt wire(supplys ground to the 12v nitrous activation wire so that while on the two step it will not allow the nitrous to be active and/or spray).
Should I wire the two step(ground) and trans brake(12v) together via a relay and then splice the interrupt wire to the 12v activation wire from my nitrous kits relay that goes to my window switch?
I know there have to of been plenty of you guys with transbrakes and two steps utilize a feature like this where while on your two-step rpm limit with the transbrake engaged the nitrous won't spray because of this, and then when the transbrake button is released the nitrous sprays.
Simple diagram will do.
JonCR96Z drew me up a little schematic for a relay to make this work and while it makes the two step and transbrake work at the same time I had someone hold a test light to the wire that gives the nitrous solenoid it's power and even on the brake/two step it's still getting power. It needs to not get power while the trans brake is engaged and then the test light should come on once the transbrake is released signaling that the relay which controls the nitrous solenoids is sending power to the solenoids, but only once the brake is released. I think.
I made a post about who should I order form, the NO outlet was recommended. I will buy my kit and hopefully they can answer all my questions what exactly I need for bolt on. Sounds like they did a good job though.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
definitely fell free to call us anytime!
#33
Guys I currently have 12v going to one side of my transbrake button. The other side of the button I have a wire going to the hot side of the trans brake solenoid. The ground side of the trans brake solenoid is grounded.
The harlan two step I have works off ground. It has three wires. One is the interrupt, and the other two are activation wires.
Here are the condensed version of the instructions.
Activation inputs (Long white and gray wires)
Relay output (Short yellow wire)
Coil Pack Connectors:
The coil pack connections are made by intercepting the PCM control signals at the large gray
connector in the center of each coil pack. The harness has 2 pairs of connectors, one pair for each
bank. Unplug the connectors on both coil packs and jumper them using the paired connectors of
the 2-step wiring harness. Either connector pair may be used on either engine bank.
Activation Inputs:
The 2 inputs can be used to provide two different modes of operation. Simple On/Off operation
and latched operation.
On/Off Operation
On/Off operation allows the user to activate and de-active the 2-step manually.
White wire(Arming Switch): Momentary switch to ground.
Normally Open, close switch to active.
Gray Wire: Connect to ground or parallel with White wire
Would I just unhook the ground solenoid from where I have it grounded on trans now, to connecting it with the white wire of the two step and then taking the two steps grey wire and hooking it to ground where I had the solenoid ground wire grounded on the trans pan?
Would that allow me to use the trans brake and two step with the same button at the same time?
If that would work then all I have to do is connect the yellow interrupt wire to my solenoids power wire so it would kill the fuel and nitrous noids on the trans brake and two step until the trans brake/two step button is released then it's game on finally.
Activation Inputs:
On/Off Operation
#35
Very nice, I currently have about 70 of the 3346 plug, once i step it up, ill switch to the 1049. Cant wait to see how your ride does. Good to see some guys battleing it out for fun.
#36
Or is it possible to take both grey and white wires from the two step(work off ground) wire them inline of each other, and ground them at the same point the trans brake solenoid wire is grounded.
Would that allow me to use my two step while on the transbrake?
I know you can't normally hook up an accessory that uses 12v with one that uses ground on the same circuit, but since there is a solenoid in between the two would it work?
I have been trying to read up on how a relay works and if I apply ground to what pin and 12v to what pin it makes this move inside which in turn makes this work and I am freaking lost.
I just either need a diagram telling me how to wire my trans brake (12v) and two step (ground) together so I can finally use my damn transbrake and two step like I've been wanting to do for almost 8 months now!
I want to launch this thing off the trans brake on a full 200 shot, but can't until I get the damn thing wired up!
****, I know I can use the footbrake but that's like fingering Jessica Biel when you could of poked her all night!
#38
I really wish I still had it right about now.
I know there is a way to wire a 4 or 5 pin relay up to allow both of them to work, but if I can wire the two step up by just grounding the two steps ground wires with the ground wire for the trans brake solenoid I'd be in business and it'd be a lot easier than having to re-wire my trans brake.
