How can i make my purge bigger
A bigger noid will do the trick most of the time. Also play with crinping the line a little at the opening to get the type of "plume" you are looking for.....
Like B18 said, its all in the tube length, given that you keep the same noid' size, i made the mistake of cutting mine shorter, now when i press the button, it laughs at me. You can actually by a longer tube if you really want to, up to like 18 inches i think. Later--DJ <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Sometimes when a hot GA day gets the fresh 12lb fill a little high in pressure, a purge is the best way out, so you may as well have a good looking one. right!?!?
But yeah, i have wasted a my share of good n20 on the stupid purge.Later--DJ
