NX Express Direct Port/Fuel System Need Help?
so I'm doing a H/C package for my 2001 camaro ss. I'm running the nitrous cam from thunder racing 224/227 .563/.569 114 LSA. And bought a pair of AFR 215 heads.Spraying 150 stock bottom end, I was wondering what I should upgrade as far as injectors,fuel pump etc
I assume you plan to pull the fuel supply off the fuel rail. I would put a rectronix fuel system on the car. This will be good for about 650 rear wheel hp. However with a directport pulling from the rail you may or may not see a lean spike issue when the fuel system activated do to the sudden fuel demand feeding the directport.
As for fuel injectors as long as you have enough injector feeding the motor you will not need to upgrade the injectors.
Here are links to the fuel system upgrade.
Harness-
http://www.nitrousoutlet.com/catalog...3&product=3721
Fuel Pump-
http://www.nitrousoutlet.com/catalog...0&product=3318
Dave
Harness-
Fuel Pump-
Dave
