two stage nx wet kit
Old Mar 9, 2002 | 06:11 PM
rich's Avatar
Default two stage nx wet kit
Hears the deal I just ordered the kit and was wondering if anyone has any info on how much a stock motor will handle. I was thinking 75 then 100 on the 2nd stage. willit survive? Other mods are 3200 stall,gmaf,under drive pulley,flp long tubes,wisper lid,wisper cold air kit,bfgdr275/40/17or26/10/16et streets,boxed lca's.This is a 2000 SS convertable a4 3.23rear gear for now possiblly 3.42rear in the future. last year it went 11.67@115mph 1.60 60ft with the bfg's stock exhaust and a dry nos kit with .036 jets. What dop you n2o guys think I could run this year?Let me know. Thanks Rich
Old Mar 12, 2002 | 07:02 AM
2000 Camaro SS's Avatar
Default Re: two stage nx wet kit
You should have no problem with your set-up...AS...long as you take all the safety precautions and use all the safety devices you can afford. With that said it has been done with a 75 dry shot off the line with a 225 direct port wet shot. It works but will take a toll on your motor. (badly) As a rule it has always been said a 100 shot no problem 150 shot with a cheater fuel pump or a up-grade in tank for safety.
