What spark plug is right for me?
Old May 26, 2012 | 03:53 PM
703 CAMAROSS's Avatar
Default What spark plug is right for me?
I know there's allot of info out there already but not for my situation. I have a 390ci, 9.6:1 compression, 853 heads, plan on runing a 250shot. Not sure if I'm going to buy a nitrous kit or if I'm just going to wait for the turbo kit. But I would like to be ready for nitrous if I'm going to use it. Changing plugs now because my engine is out of the car. Also would a colder plug make the car feel different when running N/A?
Old May 26, 2012 | 08:33 PM
Footlead's Avatar
Default Plugs
Br7ef at least. Should run fine on the motor. Mine does.
Old May 26, 2012 | 09:10 PM
INTENESS's Avatar
250 shot I would run BR8EFS I believe br7ef are a projected tip plug not good when you start running above a 200 hit.
Old May 26, 2012 | 09:24 PM
So now we wait for the next person to brake the tie haha. Although the non projected tip does make sence.
Old May 26, 2012 | 09:27 PM
Fbodyjunkie06's Avatar
BR7EF is a non projected tip, with that compression and size shot you'd toe the line for a Br7ef or a B8EFS. For a 250 hit though I'd use an 8.
May need to lean it up at idle and cruise to make it run exactly the same on the -8 I know I did. 7's I didn't notice it.
Old May 27, 2012 | 08:59 PM
So I guess il get the B8EFS then.
Old May 28, 2012 | 12:09 AM
Ask for NGK part number 1049. It will make it easier for them to locate in the system where ever you buy them from.
